OC-3??
dave
09-14-1998 10:34:43
A. C. Anderson model F3 with Hydrodozer modification by Hydraulic Equipment Co. of Southgate, Ca.
Oliver manifold on FH-4 engine with electric start, a hand-crank could not be fitted with the hydraulic pump being in the way.
5' oa width with 12" plates. The glides should mount three rollers (the back pair are missing on mine). Weighs about 3500-4000 pounds.
The blade is a grading type with about 12" raise and 30-36" depression and a right/left angle of about 45 degrees.
An oil filter from Kragen's for a 1950-4 Oliver 4 cyl. gas did fit the engine.
what is this, it works very well after I did some work on the Zenith up-draft carb?
