n series sleeves + injectors - old 3-71 block - super 99
ezed76527
10-27-2007 14:14:12
what is required to install n series sleeves/pistons & injectors in old type 3-71 block? will a special tool be needed to pull old sleeves? what special tools will be needed to set the injectors? any work arounds ?
Dave N
10-31-2007 03:26:05
 Re: n series sleeves + injectors - old 3-71 block - super 99 in reply to ezed76527, 10-27-2007 14:14:12
If you load the pistons your self be sure to load them from the bottom of the sleeve before you install the sleeve so you dont break the scraper rings. You should have the tool to install the piston retainers also and pull a vaccume on them to make sure they are sealed so oil dont leak out of them.
Lee W
10-28-2007 05:35:22
You can use a rod or bolt to put in the sleeves in the port and roll piston up and push the sleeve up. Be carefull not to us something too long and drag on the block. Have the rod cap off and pull the hole assm when the sleeve comes loose. The N series sleeve's will drop right in. The timing tool is a 1.460 timing pin unless it is A timed. If you have Detroit dealer near you I would have them load the pistons in the sleeves for you.
ezed76527
10-28-2007 20:57:55
 Re: n series sleeves + injectors - old 3-71 block - super 99 in reply to Lee W, 10-28-2007 05:35:22
thanks for the tip on removing the sleeves. i knew that a workaround must have exist for the special tool. will i have to grind anything for clearance when n piston/sleeves/injectors are installed? what is (A) timed?
Lee W
10-29-2007 07:54:48
 Re: n series sleeves + injectors - old 3-71 block - super 99 in reply to ezed76527, 10-28-2007 20:57:55
You won't have to grind on anything , A timing is advanced timing of of the cam. This was done on later engines for emissons I have been told. I built a 4-53 that I A timed and didn't see any advantage.
