Hydraulic oil leak into rear end
When to fix
10-27-2007 05:47:09
How long can a person go with this happening? 1650 Tractor gets used once every other month. Have to drain about 2 gallons out of rear plug throughout year and monitor/top off Hydraulic oil when use. As I understand this could be caused by a hydraulic pump leak among other things. Any advice helpful.
super99
10-29-2007 01:58:41
 Re: Hydraulic oil leak into rear end in reply to When to fix, 10-27-2007 05:47:09
Could be that the pan under the hyd unit has a crack in it. Depends what you use it for. If no heavy loads and only for short time, would probably get by quite a while that way. Have to remember that the rear end oil will be diluted down and get thinner all the time. Chris
