Oliver 77 Standard
Scott F
09-14-1998 07:15:37
This weekend ran my 77 Standard for a little while and for the first time heard a knocking noise coming from the front of the engine at ful RPMs. My hearing is not so good so I could not tell exactly where it was coming from. Maybe the water pump. If is were a rod or something it would not last long before the engine let go would it? Could a water pump make a knocking noise?
Dick DeYoung
09-15-1998 19:16:18
 Re: Oliver 77 Standard in reply to Scott F, 09-14-1998 07:15:37
Scott,
I can't access your post with my name. Please post again so I can reply.
Thanks!
Mike
09-15-1998 00:02:08
: This weekend ran my 77 Standard for a little while and for the first time heard a knocking noise coming from the front of the engine at ful RPMs. My hearing is not so good so I could not tell exactly where it was coming from. Maybe the water pump. If is were a rod or something it would not last long before the engine let go would it? Could a water pump make a knocking noise?
First off you should let a good mechanic listen to the noise to determine what it could be. Most mechanics won't charge for just an opinion. Also yes it could be a rod bearing or wrist pin bushing causing the knock, so take care not to run it until somebody with a trained ear can listen to it. Good Luck
