Super 55 starter questions.
T,R,K.
10-22-2007 08:50:52
'54 Super 55 gas on 6v. The starter drive is hanging in the flywheel. (The Battery is probably weak too.) I notice that the oil cup on the starter nose is upside down. Does this mean the starter is not the correct starter for the tractor, Or are they all like that?
Is the starter up to handling 12v if I decide to convert?
Any thoughts appreciated. Thanks!
rrlund
10-22-2007 14:09:16
 Re: Super 55 starter questions. in reply to T,R,K., 10-22-2007 08:50:52
It'll take 12 volts as long as you don't grind on it too long. As for the oil cup,don't know. Hanging up,it's been a while since I've had one of those apart,but if memory serves me right, (that would be the first time in a long time) that starter has a spring in the starter drive to help kick it back out. Spring might be weak or broken. Might be just gummed up and need cleaning with brake or carb cleaner.
