354 perkins in a 880
ES
10-16-2007 20:14:03
will the 354 perkin fit in 880 and what mods will it take thanks
rrlund
10-17-2007 06:12:14
 Re: 354 perkins in a 880 in reply to ES, 10-16-2007 20:14:03
No. The 354 is exclusive to the 1850. The frame is totally different. The Waukasha engines mount with 4 bolts. The Perkins uses two in the rear and a single bolt in the center in front with a rubber mount that goes around the front cover behind the front pulley. You can't even put a 354 in the frame of an 1850 gas.
gfs
10-17-2007 06:35:38
 Re: 354 perkins in a 880 in reply to rrlund, 10-17-2007 06:12:14
It can be done but not with the oliver 1850 mounts. You have to do a lot of custom work as well as cutting the waukashau mounts out of the tub in the back. It takes a bunch of work.
