Oliver 66 Gas Tank Pressure
Ohiohills
10-15-2007 18:50:12
I"ve been playing around some with a 1950 Oliver 66 RC, serial number 425014C660. I"ve noticed that when I remove the gas cap it practically explodes off the tank due to internal tank pressure. Shouldn"t this tank be vented so that no pressure builds up inside? If so, where is the vent? Can the gas cap be drilled or otherwise modified to vent this pressure? Is this pressure buildup indicative of some other problem? Or is this pressure buildup normal?? Thanks! John
J Schwiebert
10-16-2007 02:09:36
 Re: Oliver 66 Gas Tank Pressure in reply to Ohiohills, 10-15-2007 18:50:12
Somebody didn't switch the gas cap and the radiator cap which is not vented. That is why years ago the radiator caps had water written on them so if someone mixed them up in the parts bins you knew which was which or so I was I told almost 50 years ago.
bradk
10-15-2007 20:05:56
Shouldn't be any pressure.Instead of drilling it,get a new cap.Korves Bros Oliver has these.618-939-6681
