Super 55 Wanted
Mitch in Texas
10-15-2007 18:13:50
I am in the market for a nice restored Oliver Super 55. I would prefer a tractor that needs little to nothing and is within 600 miles of Brady, Texas. 76825. Is there such a creature out there?
Chris Van der Vyver
10-16-2007 13:52:48
 Re: Super 55 Wanted in reply to Mitch in Texas, 10-15-2007 18:13:50
There's a couple of nice ones on eBay right now. Not sure of whereabouts though.
But you can get a hauler for about $1 to 1.50/mile through UShip dot com and others.
SW3
10-16-2007 05:46:59
Check this out, just read it in Shep's article to the left on this site uner: Research and Info, Articles, Maintenance and Mechanical info...550 purchaser checklist. It adresses some of your questions. Good Luck. The 550 and Super 55 had rim and axle adjustments, a consideration when buying a disk so you can cover your tracks. Overall width - REGULAR TREAD is 66 3/4". New rims are not a problem. They come in 10, 11, and 12-inch widths in the 28-inch diameter. For Power Adjust It takes the same 6-loop rim all of the Fords use. The rims can interchange with Massey, Ford, and Case - 8 holes on 8". Make sure to watch the center hole diameter!! New rims run about $200 each.
The rear tires can be 26 or 28 inches with 28 being the most common. Those come in 11.2x28, 12.4x28, and (13.6x28 - this is what I have mounted) Fronts are normally 6.00x16 or 6.50x16 - again what I have mounted.
SW3
10-16-2007 16:52:28
 Re: Super 55 Wanted in reply to SW3, 10-16-2007 05:46:59
sorry, meant this reply for the rear wheels post below
Super 88 CJF
10-15-2007 18:17:01
Here is one not sure about 500 miles
http://www.tractorshed.com/cgi-bin/photoads/classifieds.cgi?search_and_display_db_button=on&db_id=189469&query=retrieval
