OLIVER 550 REAR WHEELS
cdm
10-15-2007 16:30:16
I HAVE OLIVER 550 GAS WITH 13.6 X 26 SPIN OUT REARS, 8 LUG, THAT ARE IN POOR CONDITION. IF ANYONE HAS A SET THEY WOULD LIKE TO SELL, PLEASE SEND ME AN EMAIL. ALSO, WILL THE WHEELS OFF A JOHN DEERE 420 thru 1010 BOLT ON OLIVER HUBS?
THANKS TO ALL IN ADVANCE
SW3
10-16-2007 16:54:10
 Re: OLIVER 550 REAR WHEELS in reply to cdm, 10-15-2007 16:30:16
Check this out, just read it in Shep's article to the left on this site uner: Research and Info, Articles, Maintenance and Mechanical info...550 purchaser checklist. It adresses some of your questions. Good Luck
The 550 and Super 55 had rim and axle adjustments, a consideration when buying a disk so you can cover your tracks. Overall width - REGULAR TREAD is 66 3/4". New rims are not a problem. They come in 10, 11, and 12-inch widths in the 28-inch diameter. For Power Adjust It takes the same 6-loop rim all of the Fords use. The rims can interchange with Massey, Ford, and Case - 8 holes on 8". Make sure to watch the center hole diameter!! New rims run about $200 each. The rear tires can be 26 or 28 inches with 28 being the most common. Those come in 11.2x28, 12.4x28, and (13.6x28 - this is what I have mounted) Fronts are normally 6.00x16 or 6.50x16 - again what I have mounted.
MCL
10-15-2007 17:49:36
I have a set. 13.6-28 75% tread some cracking. NOT powershift rims. Rims are good. On a Super 55 parting out. $300. Located in central IN north of Indianapolis.
