timing on 77 Rowcrop
VA Gasman
10-12-2007 17:58:19
I recently bought a 77 and it has run good. It has a little problem cranking smooth. It tries to stop like it's to much compression on one cylinder and then takes off cranking again. I thought it was the starter so I had it completely rebuilt purchased a brand new battery installed new cable connections . Brushes, armature, fields, bearings ,bendix springs, gears bushings. that was costly . Still does it. reminds me of a car that is out of timing. It has the power but makes me feel it has more to give. How do you check timing on this 77. Thanks,
J Schwiebert
10-13-2007 03:53:52
 Re: timing on 77 Rowcrop in reply to VA Gasman, 10-12-2007 17:58:19
Before you get your timing light out, take the little plate off in front of the bellhousing down by the oil pan. Turn the flywheel untill you find the mark SPK stamped in the flywheel. Clean that area and then put a little white paint on that line. Put your plate back on and then remove the timing window cover which is over by the steering shaft. The engine is timed at rated speed so you will need to run the engine wide open so to speak. Then turn the distributor so that line is visiable with your timing light in the center of the timing window. Also before you start, make sure your point gap is correct 18 to 22 is fine. Point opening does affect timing. Questions? J.
