3 point for OLIVER Super 77
oliver440
10-12-2007 13:53:51
Was there a orginal 3 pt for a OLIVER Super 77 ? Where can you find them? THANKS
Vito
10-13-2007 09:51:21
 Re: 3 point for OLIVER Super 77 in reply to oliver440, 10-12-2007 13:53:51
I was lucky enough to find a hydra hitch.The bad part it is nearly impossible to find parts for it, let alone a set of working hydra electric controls.
Vito
J Schwiebert
10-13-2007 05:16:59
The name of the Oliver hitch is a "Hydra-hitch". I am also not real sure if it was availbel when the Supewr's were introduced in 1954. Also remember Fleetline tractors had factory three point hitches available as options as well, Also remember back in the 50's a farmer with a Rowcrop tractor didn't think three point. Kinda going that way again. The boys have 3 three point hitch tools, a blade in case it snows, a ditchbank mower and a landleveler.
770
10-13-2007 06:56:53
 Re: 3 point for OLIVER Super 77 in reply to J Schwiebert, 10-13-2007 05:16:59
Would a power traction hitch fit on a super? I know you can still find these here and there....
1755
10-13-2007 20:22:56
 Re: 3 point for OLIVER Super 77 in reply to 770, 10-13-2007 06:56:53
the bolt holes in the botom of the trans that the power traction hitch are bolted on with are not there on the supers if I remember right
oliver440
10-13-2007 09:29:40
Do you know of a 3 pt for my Super 77? Great tractor has the hydra on it . THANKS
J Schwiebert
10-13-2007 07:20:20
I would not try it. That is one reason you check the transmission oil level on the side of a 770/880. The Power traction hitch covers that area. Right now I am trying to remember if there are holes in different locations for the hitch that would not be on a Super. Buy a good Fiat like a 1355 or 65. if you need a 3 point!.
m kuhns
10-13-2007 04:04:02
I think tractor supply or some other chain store like that offered an aftermarket 3 pt. Factory 3pt is hard to come by.
Mike (WA)
10-13-2007 09:08:48
 Re: 3 point for OLIVER Super 77 in reply to m kuhns, 10-13-2007 04:04:02
As with any add-on 3 point, it won't have draft control, so won't be able to plow with it- would work fine with a bush hog, or anything that you just need to carry around on the 3 point- like sprayer, pallet carrier, etc.
10-13-2007 19:25:53
 Re: 3 point for OLIVER Super 77 in reply to Mike (WA), 10-13-2007 09:08:48
No 2 or 3 digit had draft control even with factory 3 point hitch!!
ejr-IA
10-12-2007 17:43:34
My father inlaw has one on his.You would be extremly lucky to find one but someone may have a parts tractor with one for sale.
