white tractor parking gear question
jim ball
10-12-2007 09:49:53
i am thinking about buying a white 2-85 or 2-105 or 2-135. at what point did they put parking gear
in them ? series 3 ? also, what is advantage of variable displacement hydraulic pump vs earlier models ?
Dean Barker
10-12-2007 19:52:57
 Re: white tractor parking gear question in reply to jim ball, 10-12-2007 09:49:53
The 2-85 and 2-105 use gravity to fill the variable displacement pump, so you have to use Type 55 oil or it's equivalent which is thinner than universal hydraulic oil. The 2-135 uses a charge pump to pump oil the variable displacement pump so universal hydraulic oil is used. If you are going to do any heavy work, the 2-135 will be a much better tractor for you.
Wrenchbender
10-12-2007 14:05:01
The 2-85 and 2-105 both used the hand brake that set the brake disks. The 2-135 used a mechanical paw that locked a gear in the transmission, that started with the first series. WB.
J Schwiebert
10-12-2007 12:26:23
The variable displacement pump is more effecient/ Thr 55 series Olivers used the variable displacement pumps also. It is a closed center system. More later , gotta go. J.
