Head gasket
martin fleming
09-12-1998 17:43:33
Here's what might be a stupid question,
I'd like to take off the head on my OC-3 crawler. Will I have to replace the head gasket (as long as I don't screw it up when seperating the head from the engine)? I know to do so with a newer car engine, but is this also the case with older Hercules engine?
~martin fleming
don
09-12-1998 21:17:27
 Re: head gasket in reply to martin fleming, 09-12-1998 17:43:33
Probably not supposed to, but we have re-used many head gaskets. It depends on the condition of the old gasket - judgement call here. If you didn't damage it taking it off and it is not too corroded,leaking,or otherwise damaged then you'll probably be ok since most of these old engines have relatively low compression. Before re-installation, make sure the gasket,head and block are buffed clean. A scotch pad on a die grinder works great. Go easy on the gasket so as not to damage it. Also, use a good sealer. We have had good luck with copper coat spray. : Here's what might be a stupid question,
: I'd like to take off the head on my OC-3 crawler. Will I have to replace the head gasket (as long as I don't screw it up when seperating the head from the engine)? I know to do so with a newer car engine, but is this also the case with older Hercules engine?
: ~martin fleming
