carb rebuild
eeeeeeeeeeeeeee
10-08-2007 06:40:46
can anyone tell me any tips on rebuilding a tsx 120 off a 60 like good solvents to use, best ways to get jets out ,etc
thanks, rob
oliveroliver
10-08-2007 16:48:02
 Re: carb rebuild in reply to eeeeeeeeeeeeeee, 10-08-2007 06:40:46
What ever you do, don't use acid base solvents. They will eat away the iron and you will not get your jets or screws back in (the holes will be to big). If carb is really bad, use a sand blaster. It will not hurt the carb. If you need to take the jets out but they are stuck, heat them, but not so much that you melt them.
cmccoy7
10-08-2007 07:06:09
Well I use laquer thinner to clean that kinda stuff ( I think it is the same as carb cleaner). Getting jets out....not so easy. I leave them in if they'll not come out willingly. I just make sure the hole is cleaned well with laquer thinner and compressed air ( I also have some very fine dental tools I use to clean delicate areas like this). Another tip I give is if you are not in a hurry then put your entire carb in a small bowl of diesel fuel and let it soak for a week or two. It really make things come apart really well and they clean up so nice. Chris
