engine rebuild on a 770
cmccoy7
10-08-2007 06:36:09
I just recently rebuilt my 770 engine and have since blasted, cleaned and painted everything else. I placed my engine back into the frame of the tractor and bolted it down using two dowel bolts as the book stated. It all went together very well. My concern is this, the book says to use a dial indicator to make sure my engine alignment matches my tranny shaft. I did get a different 770 block(crack in the old block). What is the likely hood that I could be out of alignment? Should I pull the bellhousing off and try to use a dial indicator on it, I don"t have one nor have I ever used one? What do you all think? Would I feel any vibration if I was out of alignment? If you have had any experience with this please chime in. How many of you have had to shim your engines after replacing the engine to get it in alignment? Chris
cmccoy7
10-09-2007 09:57:40
 Re: engine rebuild on a 770 in reply to cmccoy7, 10-08-2007 06:36:09
Thanks RAB for the info and suggestions. I never had any shims under the original engine. I have also taken a couple Oliver 88"s apart and they never had any shims under them either. Has anyone out there ever pulled one of these apart and actually found shims? Please let me know. Chris
RAB
10-08-2007 12:42:53
Chris,
Were there any shims under the old motor? I suspect there were as it plain easier to manufacture with the engine always low, and shim it to the right height and straight at build time. Just impossible to do it the other way round and getting everything spot on for all tractors was not within the tolerances of casting and machining.
Likelihood of being out of alignment? About 100%, I would think, if you are using no shims! You might be close with the original shims, if you are lucky.
Comparing to space technology, or even more modern tractors, the tolerances may be much larger for the 770, but it is likely to ruin something if it is outside the limits set down by Oliver. That is why they had those limits, after all!
Regards, RAB
