Hydraulic valve for 1800 series B
Rexalot
10-08-2007 04:50:15
I have an 1800 series B that is missing the the shutoff valve or "priority valve??" the permits use of the three point when there is no hydraulic cylinder attached.
This valve is shown in my IT manual and it would be installed on the front of the electro hydraulic switchpack on the right hand side.
Currently my tractor has a single solid line going from this port down to the operators platform. To use my three point hitch I have to remove this line and install plugs at both places.
While this works fine for occasional use I'm at the point that I would like to use the three point more often, but I also have a need to run the remotes. Making the switch makes a mess with the fluid getting everywhere.
My local AGCO dealer gives me that "far way look" when I inquired about a replacement. Anybody have an idea where I might find one or a suggestion for a replacement?
J. Schwiebert.
10-08-2007 05:30:17
 Re: Hydraulic valve for 1800 series B in reply to Rexalot, 10-08-2007 04:50:15
When I get back home I will look to see if I kept your e-mail address. Anyhow I need your phone number. I will be back tomorrow. I owe you one. J.
