770 transmission problems
johnny5
10-07-2007 19:21:43
got a 770 with a double h shift pattern. When in lower section the transmission makes a grinding noise but will not move.When in upper section the transmission makes a lesser noise but will move. Any thoughts?
RAB
10-08-2007 12:56:10
 Re: 770 transmission problems in reply to johnny5, 10-07-2007 19:21:43
Help us a bit.
When you say 'not move' are you referring to the selector gate or the tractor?
When you say 'lower section' is this lower and higher gear ratios or position of selector?
This noise - it it deafening and less so, or just normal gears not engaging?
Could be cluth, gearbox, back axle or selector. Can't tell from your post.
RAB
johnny5
10-09-2007 05:39:37
 Re: 770 transmission problems in reply to RAB, 10-08-2007 12:56:10
RAB, The tractor will not move when the position of the selector is in the lower section. The noise, not quite deafening but not normal. Sounds like the gears are not meshed correctly. The tractor will move when the position of the selector is in the upper section, example 3rd. The noise is different, more like normal gear mesh but when under load the noise increases, and sounds like the gears are not fully meshed. Could I have a bent shifting fork? Thank you for your help.
