Super 55 vs. 550 Parts
John P.
10-06-2007 11:05:26
Can someone with both a 550 and a Super 55 parts book tell me if the clutch pedal and the shaft that goes through it is the same part number on each tractor?
SPMN
10-07-2007 15:35:50
 Re: Super 55 vs. 550 Parts in reply to John P., 10-06-2007 11:05:26
Hi John---I have alot of pedals and shafts for Super 55's & 550's and I'll have the one you need---My email is open---Thanks
Kent
John P.
10-08-2007 08:32:31
 Re: Super 55 vs. 550 Parts in reply to SPMN, 10-07-2007 15:35:50
Thanks Kent, but I found one in AR last night that is being shipped out this week. I will send you a check for the tool box when I get your email with the total.
Chris Vyver
10-07-2007 09:39:21
To try and help:
For a 550
the clutch pedal is 100 562-A
the shaft that runs through it is 100 564-A
now you need someone with the 55 parts manual
John P.
10-07-2007 09:43:36
 Re: Super 55 vs. 550 Parts in reply to Chris Vyver, 10-07-2007 09:39:21
OK, we're half way there!
John
J. Schwiebert.
10-07-2007 10:08:03
 Re: Super 55 vs. 550 Parts in reply to John P., 10-07-2007 09:43:36
Well first of all I would ask you for the last 3 digits ofyour serial number. When the Super 55 went to a 519 final drive from the 518 used earlier a lot of small changes were made especially in the center housing. Those two number given to you on the 550 were also used on the later Super models. So now I would need information from you. J.
John P.
10-07-2007 10:32:23
 Re: Super 55 vs. 550 Parts in reply to J. Schwiebert., 10-07-2007 10:08:03
Hi, the tractor is a -518.
John
J. Schwiebert.
10-07-2007 13:32:32
 Re: Super 55 vs. 550 Parts in reply to John P., 10-07-2007 10:32:23
Wgt do you want to change the petal?
John P.
10-07-2007 13:39:20
 Re: Super 55 vs. 550 Parts in reply to J. Schwiebert., 10-07-2007 13:32:32
The pedal and the shaft it rotates on are both extremely worn due to years and years of use without being greased and they wobble real bad because the hole though the clutch pedal is now oval shaped and just flops around on the shaft.
J. Schwiebert.
10-07-2007 15:17:05
 Re: Super 55 vs. 550 Parts in reply to John P., 10-07-2007 13:39:20
Oh man you caught me off guard. But have you thought of taking the petal off and bore or hone it for a bushing.
John P.
10-07-2007 17:07:44
 Re: Super 55 vs. 550 Parts in reply to J. Schwiebert., 10-07-2007 15:17:05
I figure it would be easier and faster to just replace them with something better.
J. Schwiebert.
10-08-2007 05:32:06
 Re: Super 55 vs. 550 Parts in reply to John P., 10-07-2007 17:07:44
You know you have to split the tractor to change the shaft which may be good because it it worn in the case I would bush it to. J.
John P.
10-08-2007 08:29:57
 Re: Super 55 vs. 550 Parts in reply to J. Schwiebert., 10-08-2007 05:32:06
Good thing I plan on laying it up for a while then. I will check the case as you suggested to see if it is worn when I have it apart, but I think (and hope) all the wear was in the pedal to shaft joint. I found a clutch pedal and shaft from a gentleman in AR, who is shipping them to me this week. The tractor he is parting out was made a little before mine was so it is a -518 also.
J. Schwiebert.
10-08-2007 10:44:02
 Re: Super 55 vs. 550 Parts in reply to John P., 10-08-2007 08:29:57
while you have it split I have some suggestions on some other things to check. Send me a phone number or U. S. mail address.
John P.
10-08-2007 15:34:30
 Re: Super 55 vs. 550 Parts in reply to J. Schwiebert., 10-08-2007 10:44:02
Need your email.
John
1755
10-07-2007 19:42:33
This is not the anser but an idea if your Agco dealer will do it for you they can look up both on the computor and tell whether they are the same part number or not at least my dealer has done it for me before
RCP
10-06-2007 15:43:59
I can"t guarantee it, but I believe they are different but can be interchanged as a set.
John P.
10-07-2007 12:19:28
 Re: Super 55 vs. 550 Parts in reply to RCP, 10-06-2007 15:43:59
It gets really confusing without a manual to back yourself up with.
