88 transmission input shaft bearing
Dave Sherburne
10-04-2007 17:50:32
What is involved in replacing this bearing? can it be done from the clutch area?
J Schwiebert
10-05-2007 04:16:32
 Re: 88 transmission input shaft bearing in reply to Dave Sherburne NY, 10-04-2007 17:50:32
Easy job: Of course you need to remove the PTO, transmission cover and belt pulley gear box if you have one. Make yourself a "slug as we called them) to fit inside the shaft and drive it out from the back. Replace both the front and rear bearings together. Questions? J
