oliver 550 saginaw power steering
oliver t griswo
10-03-2007 04:40:15
third party image
the high pressure line to my saginaw power steering valve is loose at the fitting. the nut seems to be froze to the steel line. should it be loose so i can back it out or do you have to take the entire valve out to spin out the nut / line? thanks much!
J.Schwiebert
10-03-2007 15:50:17
 Re: oliver 550 saginaw power steering in reply to oliver t griswold, 10-03-2007 04:40:15
They are inverted flare type fittings no gasket.
Mike (WA)
10-03-2007 13:05:46
Yes, the nut needs to be able to turn without turning the line, or the line will twist and be ruined. Try tapping the line back and forth gently, and spray some Kroil or PB Blaster as you're doing it. Chances are you'll end up replacing the line anyhow (don't know how you'd fix the fitting after you get it off- not enough clearance up above to cut off the line for a fresh place to crimp)- so if it won't loosen up, just cut the line and get it off that way. Might be best if you'd located a new line first.
oliver t griswold
10-03-2007 13:13:09
 Re: oliver 550 saginaw power steering in reply to Mike (WA), 10-03-2007 13:05:46
is this line part readily available? what seems weird to me is that apparently the nut and line are froze together yet the nut/bolt is turning freely in the valve housing; it"s not tight at all. is there a gasket or something that may have disintegrated? i"ll give it another day or two and then cut it i guess. thanks!
