Block Heater in 550
Robert Shirley
10-02-2007 09:10:03
I was wondering where the best place to install a block heater on a 550 would be. I have looked and can't see any frost plug ports. Is it best to just install a circulating heater in the bottom rad hose?
SW3
10-03-2007 18:59:21
 Re: Block Heater in 550 in reply to Robert Shirley, 10-02-2007 09:10:03
I have a lower radiator hose heater that works well. Tight fit, near the fan belt. Gas engine and COLD northern MN winters. Good Luck
Super 55
10-02-2007 17:12:41
I had lower rad hose heater. It worked well, but it doesn"t get too cold in the Fraser Valley of BC.
El Toro
10-02-2007 15:49:29
I would go with the tank heater too. Hal
http://www.kimhotstart.com/
El Toro
10-02-2007 15:49:20
rrlund
10-02-2007 10:09:55
That circulating tank heater was what we had on our Super 55 diesel.
86turbodsl
10-16-2007 11:26:27
 Re: Block Heater in 550 in reply to rrlund, 10-02-2007 10:09:55
The stock location is in the lower radiator hose. I checked and all the parts are still available. Should be about $50 from a dealer.
