Cockshutt 30 oil pressure restrictor
steve scobee
09-29-2007 20:34:42
Hi, Does anyone know if the Buda 4B153 had a restrictor going to the rocker arms?(line between block and head) My engine has no restrictor, but it seems that I've read that they should have. If it supposed to be there, does anyone know the approximate size of hole in the retrictor? Thanks, Steve
cj in wisconsin
10-01-2007 05:13:56
 Re: Cockshutt 30 oil pressure restrictor in reply to steve scobee, 09-29-2007 20:34:42
According to my literature there is no restrictor but if you do any head work you must nake sure the rocker arm support stud with the groove in it is in the frt. That is were the restriction is and also were the rockers get their oil. I have 2 model 30 s and 1 model 40 and they are set up that way.
