oliver 550/55 belt pully and ford
havvey
09-29-2007 20:02:15
Anyone tried a ford pulley on the 550/55? wondering if it would work?
rrlund
09-30-2007 08:35:27
 Re: oliver 550/55 belt pully and ford in reply to havvey, 09-29-2007 20:02:15
The ones for the 8n and such would have been a smaller PTO shaft. I've wondered myself if there was a later one that would work.
Dick Witmer
09-30-2007 11:29:20
 Re: oliver 550/55 belt pully and ford in reply to rrlund, 09-30-2007 08:35:27
Our S55 has a reversable pto shaft with the smaller size on the one end. It is the same as the old Fords. I also wondered if a Ford pulley would fit the bolt pattern. Have a good day.
Larry from md
09-30-2007 15:47:44
 Re: oliver 550/55 belt pully and ford in reply to Dick Witmer, 09-30-2007 11:29:20
When i tryied one years ago it would not go on. Something was wrong with the bolts. I figured i could do it with some mods.
1755
09-30-2007 18:44:45
 Re: oliver 550/55 belt pully and ford in reply to Larry from md, 09-30-2007 15:47:44
There were 2 Ford gear boxes one had the small splines and the other had the regular 540 splines Grandpa had the old Ford with the small splines and got a new gear box pully and all when he got the Ford 3000 they ran a 3pt buzz saw and the sheller with them
we got one of the ford 3pt buzz saws we run on our 550 but we have an Oliver S55/550 pully on there we got from a salvage yard I think your best bet would be to find one of those but if you are crafty I was told there are some gear boxes off combines that are 90degre that are 1 to 1 the Oliver pully also has to have the stub shaft pulled out of the back to put it on there we had to have ours taken out when we had the motor and clutch done and they had to press it out it was in there so tite but this tractor had not had any thing put on the pto until we got it
