Cockshutt 30 40 50 oil pressure
cj in wisconsin
09-29-2007 05:35:26
Just thought I'd share a little info that I recently learned. I have a 40 that was showing way too much oil pressure cold and not enough hot. First thought was the obvious, mains or cam bearings. Pulled the pan , bearings good with proper clearance. Checked the oil pressure relief valve found it stuck partially open and deformed. The last person in this engine had installed a bolt that was too long in the cam retainer plate and it went through and held the relief valve open and deformed it. Don't know if this will help anyone but I figured I'd share a lesson learned. On the good side she purrs like a kitten now. Love those Buda 6 cylinders!!!!
