Super 77 Carb Problem
Steve Kuhler
09-26-2007 17:17:13
My 77 ran like a champ until I put some bad gas in it, now it won't even fire. I took the carb apart and cleaned out all the holes, everything acts like it's open. The main gasket fell apart when I opened it. I put it together without it (which is a problem I know), now I need to figure out which model carb it is. Anyone have a reference I can use? Where can I find a new gasket? It acts like it gets too much gas, what should the float be set at?
770
09-27-2007 13:48:36
 Re: Super 77 Carb Problem in reply to Steve Kuhler, 09-26-2007 17:17:13
My local NAPA has kits for both MS and Zenith carbs.
bradk
09-26-2007 20:29:19
Try kit for carb #TSX 363 or TSX 374 for rebuild kit with specs.Also included is the recommended settings of the air bleed and enrichment screws.
~brad
Mike in MI
09-26-2007 17:57:44
Steve,
Not sure if I be much help? The carb should have a brass tag on it. I have the Zenith on mine and the tag is located at the top of the carb toward the front of tractor, tag should be about the size of a dime. If you had the Marvel Schebuler carb it should have a brass tag on throat of the carb. The bowl should have Marvel Shebuler stamp on the side of it.
I got my carb kits at the local auto parts store.
Mike
