Front rim size Cockshutt 40
cj in wisconsin
09-26-2007 16:26:30
I recently aquired a model 40 serial # 131 so it is a very early model it has 17 inch frt wheels on it. I dont know if they are correct, all I have ever seen are 16 s . It also has one incorrect rear wheel and would like to find an original in the Mn Wi area . Any help appreciated.
P Heisey-Harleysville,PA
09-26-2007 18:31:19
 Re: Front rim size Cockshutt 40 in reply to cj in wisconsin, 09-26-2007 16:26:30
Hi cj in Wisconsin,
No 17 inch wheels were used on any Cockshutt built tractors.
Your early E4 should have heavy front hubs and 4.5 X 16 inch rims for a 6.00 or 6.50 tire. Later larger COCKSHUTT built tractors used 18 inch heavy cast two piece bolt together "Hernia" wheels that weigh about 300 pounds. A 5.5 X 16 wheels was also available for a 7.50 tire.
I have both of the 16 inch wheels on stock, new.
Phi Heisey 215-256-8651 FAX 215-256-1203
