semi mount plow id
karl f
09-25-2007 23:57:33
we have 2 oliver semi mount 3 pt plows with steerable tails. one is a 4-16 the other a 5-16. the four looks newer, but might be the same age. both have trip bottoms you need to back up to reset.
what model numbers could they be, and how do you tell ?
thanks
karl f
AB
09-26-2007 17:26:34
 Re: semi mount plow id in reply to karl f, 09-25-2007 23:57:33
Is the main frame box or pipe?
karl f
09-26-2007 20:58:27
 Re: semi mount plow id in reply to AB, 09-26-2007 17:26:34
square construction.
karl f
AB
09-27-2007 09:16:37
 Re: semi mount plow id in reply to karl f, 09-26-2007 20:58:27
My guess would be a #566.
Don-Wi
09-26-2007 01:30:06
If you have any pictures, they would help a bunch. some ways to tell atleast what series it is, is by the back bone and how the bottoms attatch to each other. We've got a 565 and 546, each one is different but uses the same style of bottom.
third party image
The 546 is a little bit newer.
Donovan from Wisconsin
karl f
09-26-2007 13:50:29
 Re: semi mount plow id in reply to Don-Wi, 09-26-2007 01:30:06
looks like the 4 bottom. has same white decals on the bottoms. 5 bottom looks more crude.
thanks
karl f
Rich S
09-26-2007 04:22:09
I have a 4 bottom 546 that is in need of new shares and shins. Where do you get replacements, most places do not list the Model 546. I could also use another bottom, making it a 5 bottom.
Rich S
AB
09-26-2007 17:24:56
 Re: semi mount plow id in reply to Rich S, 09-26-2007 04:22:09
For wear parts see:
http://www.cfcdist.com/pages/about.html
Don-Wi
09-26-2007 10:07:26
We get our wear parts at Fleet Farm. You go by the width of cut and the make of plow, so it's just listed as 16" Oliver, or something like that. I think the shins are the same though for the different widths. Our 565 ad 546 use the same exact wear parts.
Otherwise your Agco/Oliver dealer has them, just hang onto your wallet.
evielboweviel
09-26-2007 05:27:04
tried to sell an add a bottom on ebay 2 weeks ago no bidders. so it is sitting next to plow if we need any parts. all that is missing is bolts to bolt the backbone together and the bottom. the colter is way better than what I have on the plow
Ron
Rich S
09-26-2007 05:42:40
 Re: semi mount plow id in reply to evielboweviel, 09-26-2007 05:27:04
Where are you located? How much do you want?
email is open.
Rich S
evielboweviel
09-27-2007 16:20:49
 Re: semi mount plow id in reply to Rich S, 09-26-2007 05:42:40
Rich S
sent an email thru yt yesterday. figured you didn't get it so try rselzeratcolumbusdotrrdotcom
Ron
