Oliver S55 Carb Problem! HELP!
olrusty70
09-23-2007 17:45:58
I am at a lost right now, I am working on a gentlemen�s S55 this weekend which had been setting in his garage a while (he didn�t know how long). I put all new plugs, wires, points, & condenser. I also took the carb. off and soaked it in Castrol super clean. Put a carb rebuild kit in it new shaft, gaskets, seat and so on. The tractor ideals sooth as it should the only way I can get it to run full RPM is with the choke pull out about 3/16�. Which puts the butterfly at about a 5� angle. When the choke is pushed in it sound like it starves itself of gas and dies. I have loosened the high speed screw until it almost falls out while the tractor is running & choke pull out, and it has NO effect. The carb is clean I have taken it apart about three times thinking I missed something inside. Clean anyone point me in a direction to try to fix this thing. Or could it be something other than the carb?
Thanks in advance!
