need help with a rear end problem on a 77 row crop
Chris East
09-23-2007 17:14:23
right side differential gear has slid in toward the big gear to the point it ids not on the gear inside of it. tractor will not hardly pull itself until you push the right brake then pulls with left tire. my question is what hold the differential gear in place, I can not find it in the service manual.
Chris East
09-24-2007 06:45:47
 Re: need help with a rear end problem on a 77 row crop in reply to Chris East, 09-23-2007 17:14:23
Its the gear on the side ,probally 4 in tall, that fits on the gear that drives the axle gear. it has slide back inside the bull gear or limeted slip mech. whatever you call it. what keeps that little gear from sliding around?
rrlund
09-24-2007 12:14:26
 Re: need help with a rear end problem on a 77 row crop in reply to Chris East, 09-24-2007 06:45:47
I've got the exploded view of it right here in the I&T manual. It shouldn't move unless the bearing is out on the outside. But you said it is slid in? Is the bearing OK in the opposite side? The shaft and spider is one part and the bull pinion is another. The gear and shaft (bull pinion) are one. Bull pinion slides over the spider shaft. In other words,there are only three parts. Left bull pinion,right bull pinion and spider-shaft.
Chris East
09-24-2007 12:38:54
 Re: need help with a rear end problem on a 77 row crop in reply to rrlund, 09-24-2007 12:14:26
it has slid in of the shaft. you can even see where it sat from the color. if you will email me your tele# i will call you and explain while looking at it. or you can call me if you wish (931(624-4135
J Schwiebert
09-23-2007 18:08:13
I tired and maybe I missed something. Are you talking the bull pinon or the side gear? Does this tractor have disk brakes? How much do you have apart? J.
