Oliver 770 Gasoline tractor
Blue Horse
09-19-2007 05:05:56
I know of a nice low-hour 770 gas tricycle for sale nearby. Not knowing much about Oliver's, could some who are tell me a bit about the strong/weak points of this model? How is fuel consumption compared to other makes of this size? I would use it mainly for planting and harrowing if I bought it.
Blue Horse
09-21-2007 05:29:13
 Re: Oliver 770 Gasoline tractor in reply to Blue Horse, 09-19-2007 05:05:56
Thanks for the comments. Relating to hydra-power, which apparently is Oliver's version of IH's torque amplifier, is it a fairly reliable unit on these tractors? Is it a fairly expensive unit to repair/replace?
Kruse
09-19-2007 16:06:57
Probably the only real weak point is that it burns gas. Priced any lately? ;-)
j105
09-19-2007 15:45:49
770 is a very good tractor, one of oliver's most popular. based on a proven design that was used for years. i can't think of many weak points, maybe the fact that the three point doesn't have draft control. it doesn't sound like that will be an issue for your intended use though. as far as fuel consumption it's probably going to be about the same as any 50 horsepower tractor of that era. i would guess around 3 gal per hour under full load. but not near as much with a light load like a hay rake, or three section harrow. one thing you will notice when you first drive the 770, there will be noticable gear noise or whine in the rear end. this is normal for that tractor. i don't mean growling or grinding though.
