540 cockshutt Hyd pump
Mark Salyers
09-18-2007 07:03:56
Need Help: just bought a 540 cockshutt that is missing the hyd pump. need info about getting one or a possible substitute.
Mark Salyers
09-21-2007 16:34:37
 Re: 540 cockshutt Hyd pump in reply to Mark Salyers, 09-18-2007 07:03:56
Phil, just got off the hone with Vickers/Eatons on the pump issue. vickers has a new # for the 540 pump. the number is v10-1s-3s-3c-20. it is a direct replacement. i found a distributer in michigan to get the pump from. brand new the cost is 450.00.
Mark
P Heisey-Harleysville,PA
09-20-2007 03:16:01
MARK,
THANKS for your call and phone message last eve.
I will call you this eve.
Phil Heisey
09-19-2007 01:58:53
Mark,
I can assist you with the pump info. for your COCKSHUTT 540. I probably have some of the parts that you will need.
Phil Heisey 215-256-8651 FAX 215-256-1203
