Oliver 60 engine parts
Solid Junk
09-13-2007 08:06:48
What is a good source for rings, bearings and such for an Ollie 60? Ours is getting pretty weak, and I would like to start gathering parts to rebuild her this winter or next spring.
Thanks
Joe
Tip
09-14-2007 18:12:14
 Re: Oliver 60 engine parts in reply to Solid Junk, 09-13-2007 08:06:48
Korves Brothers (618-939-6681 and on the web)
Farmersville Equipment ((717) 354-2150 )
Both great places to get parts and knowledgeable folks. Sorry I don't have numbers handy.
Regards, Tip
Solid Junk
09-14-2007 12:42:42
Ok thanks for advice, but I would still like to know WHERE to get parts. I'm not new to rebuilding old tractors, I just don't deal with the green ones much. I thought there might be a supplier out there that everyone has had really good luck with. I collect MM's and whenever anyone asks about parts for them there are 2 or 3 names that pop up quick. Thought it might be the same with Olivers.
Joe
Ken L.
09-13-2007 15:39:54
As havvey said, first tear it down and find out just what you need and what sizes. If I remember right, 77 bearings will fit but, you will have to drill new oil holes in them to make them line up. Rings are no problem. I have a set of decent sleeves and a set of sleeves and pistons. I also have a couple valves that are in good cond. You can get a complete overhaul set as I did but, it's expensive.
havvey
09-13-2007 09:23:25
I would tear down first to see what and size needed.
