77 RC Shift Pattern/Hi-Lo Range?
Dale
09-12-1998 06:39:49
Does the 77 have a high and low range tranny? I don't have an operators manual so I was wondering how you get the six forward speeds from a three shift pattern. I must be missing the obvious.
Thanks!
Pete
10-05-1998 18:50:29
 Re: 77 RC Shift Pattern/Hi-Lo Range? in reply to Dale, 09-12-1998 06:39:49
: Does the 77 have a high and low range tranny? I don't have an operators manual so I was wondering how you get the six forward speeds from a three shift pattern. I must be missing the obvious.
: Thanks!
Dale, on a piece of paper, draw a capital H, then draw another H directly under it without it touching the upper one. Now, draw a straight line from the upper H cross bar to the lower H cross bar right down the center of the H's. That's your shift pattern. And have a nice day!
Pete
Mike
09-12-1998 10:33:15
: Thanks!
The gear shift lever sets in three shift rails in the transmission. With the gear shift lever in the center position pull the lever back to the high position and push it foward into the low position. In the low position the knob will be very close to the dash, so watch your fingers. Good Luck
Mike
09-12-1998 10:32:51
: Thanks!
