70 sleeves and pistons
oliver man
09-10-2007 14:50:13
i am completly rebuilding an oliver 70 and want to know what i should do to the pitted pistons and sleeves without getting new ones
Flyin Farmall
09-10-2007 16:16:15
 Re: 70 sleeves and pistons in reply to oliver man, 09-10-2007 14:50:13
Hi,
I have a set of aluminum pistons and sleeves.These were in stalled ran for a VERY short time,then I bought the tractor to build a puller.I will sell them to you pretty cheap,they are almost new!! My e-mail is open.
oliver man
09-10-2007 16:51:13
 Re: 70 sleeves and pistons in reply to Flyin Farmall, 09-10-2007 16:16:15
do they have rings on the pistons and are they for a OLIVER not hart parr 70 and how much do you want for them?
Flyin Farmall
09-10-2007 19:51:18
 Re: 70 sleeves and pistons in reply to oliver man, 09-10-2007 16:51:13
Hi,
they do have rings,and yes they are for the Oliver,not the earlier Hart-Parr.I was thinking around $200-250? E-mail me.
oliver man
09-10-2007 15:40:12
i will probably have to get new pistons and sleeves does any body know who or where to get them?
J Schwiebert
09-10-2007 15:25:37
The low dollar answer is depending on if you have the 3.125 bore cast iron piston as when Oliver built the tractor or the more popular aftermarket 3.250 bore engine with aluminum pistons. Either way I would have the sleeves bored to accept an oversize aluminum piston. Not a big deal. Another problem may be that not all bearing sizes are available anymore. Measure everything up and see what you need.
e
09-10-2007 15:20:28
I have a good short block for you if interested. You can hardly catch your nail on the cylinder ridge. I'm in WI and my email is open.
Kruse
09-10-2007 15:16:49
Depending on the condition of your old parts, if you are reusing the pitted pistons and sleeves you are not completely rebuilding your 70.
