28-44 water pump packing nut
Duane Larson
09-10-2007 06:33:03
We're working on a fellows 28-44 at our local fair, and the water pump packing is leaking. There is a large brass nut with the water pump shaft going thru it, and accessible from the pulley side of the engine. There does not appear to be an adequate opening to put a wrench on it (at least the ones we had) - so a couple of questions..
1) is that the nut to loosen to add packing
2) was there a special wrench to turn it
Any help with this general topic will be appreciated. We are replacing the radiator core at the fair and the owner said there was water pump leakage also so we'll try to fix that.
Thanks in advance!
RAB
09-10-2007 08:32:33
 Re: 28-44 water pump packing nut in reply to Duane Larson, 09-10-2007 06:33:03
It is the greasy packing which is leaking. The nut only retains and expands it - just tight enough against the shaft and housing to prevent leakage. Too tight and excessive heat will be produced which will ultimately destroy the packing. May just need tightening with the nut. May need more/better grease. May need repacking. Whole shaft may need replacing. Most likely a minor problem.
Yes, I daresay the usual monkey wrench will not fit. A socket is no good either!!!! A water pump spanner is usually narrow, in the form of a curve, with one or more lugs at the end to 'hook' around the nut, or similar with flats on it. Depends on the form of the packing nut.
Hope this helps.
Regards, RAB
Duane Larson
09-10-2007 08:49:17
 Re: 28-44 water pump packing nut in reply to RAB, 09-10-2007 08:32:33
RAB,
Thanks for the response - I dug out my old OTC spanner wrench and will go give it a try. We have packing - I suspect the original packing is still in there (or what's left of it).
