WHEEL WEIGHTS
LUKE ERPELDING
09-09-2007 18:07:20
Is a h-1245 a front wheel weight for an oliver? If so what models?
oliver fan
09-10-2007 08:38:15
 Re: WHEEL WEIGHTS in reply to LUKE ERPELDING, 09-09-2007 18:07:20
The H 1245 wheel weight is for the early 60 tractors, only. That weight was replaced with the H 1245-A weight. The differance between the two is the earlier weight mounted to the rim with J bolts that hooked in the slots in the rims. The later weights had two more holes in them and mounted to the rims with 2 bolts that matched up to the bolt holes in the rim. The H 1245-A weight is the one that will mount on a 60 as well as the Fleetline, Super or 660 tractor with pressed steel front wheels.
Big Marv
09-09-2007 20:27:51
That is an Oliver part number. The parts book for the 550 and 66/660 both list your part for their front wheels, for inside and outside mounting. I imagine they will fit most any 16 inch wheel with the four square holes for mounting.
