telescoping wheel
Greg Gramps
09-08-2007 16:23:24
I have asked this in the past,Does anyone have any ideas on how to free up that dang telescoping steering wheel on an 1800 ollie. I have tried P.B. Blaster for months with no avail. Is there a way to tap on it from the inside maybe. Thanks guys.
rrlund
09-08-2007 16:49:18
 Re: telescoping wheel in reply to Greg Gramps, 09-08-2007 16:23:24
Maybe it'll help you to know how it works. Remember the gooseneck on bicycle handlebars? The chrome steering shaft is cut on an angle at the bottom. There is a threaded rod that screws in to the bottom "wedge" and comes up in to the cap that turns in the center of the wheel.Take the nut off and remove the cap and put you're PB Blaster or WD 40 or whatever down the inside. Put something like a nut or whatever on the end of the threaded rod and tap on it to drive it loose from the top part. Now just kind of pull up and push down on the steering wheel and try to work it loose,or tap it. There isn't really a seal to speak of at the top of the shaft,there is just a needle bearing in there,so light oil or WD 40 should get past it on the outside. Clear as mud? Best I can describe it.
