Oliver 1850 PTO brake won't hold . . .
Steve H
09-01-2007 08:39:56
Just wondering if anyone has a cure for this. I have the PTO with the lever on the left. I put a new PTO clutch in 2 years back and a new "brake." Basically a large washer, which apparently does very little. I have the clutch adjusted (per book) at about 10 lbs lighter than it should be. I can get it to stop on my baler if I disengage it with a wad of hay in it still but that's about it. Any suggestions? Will another "brake washer" help (2 vs. 1?) I hate to tear it apart again.
Thanks . . .
J Schwiebert
09-01-2007 09:24:14
 Re: Oliver 1850 PTO brake won't hold . . . in reply to Steve H, 09-01-2007 08:39:56
The answer to your last question is NO: How much do you use the PTO? I will send you an e-mail or you send me a phone number. J.
Steve H
09-02-2007 06:17:51
 Re: Oliver 1850 PTO brake won't hold . . . in reply to J Schwiebert, 09-01-2007 09:24:14
This is my main tractor, I use it to cut hay with a NH 489, bale hay with a JD 24T, and now have a newer manure spreader H&S 125 PTO version. So I do use the pto often. It really gets annoying with the pto deciding to "engage" when ever it wants. My e-mail is [email protected] cell # is 440-667-1420.
Thanks . . .
