Super 88 govern
PtownBubba
08-31-2007 05:42:39
I found a used governor for my Sup.88. My question is, on the engine or gear shaft end, is there suppose to be a spacer or thrust washer on gear-end shaft. or does it just go in as is ?
PtownBubba
08-31-2007 07:54:53
 Re: Super 88 govern in reply to PtownBubba, 08-31-2007 05:42:39
ok,,, thanks. I know it has the little bearing with washer on the end towards the front of tractor, was not sure about the larger shaft size,, gear-end.
Thank You again.
J Schwiebert
08-31-2007 06:22:14
You need a thrust washer first. Part number K-289. That may have been superceeded.
Greg Raser
09-04-2007 12:35:24
 Re: Super 88 govern in reply to J Schwiebert, 08-31-2007 06:22:14
Can you tell me where I can order this thrust bushing ?
