ever keep track of your hours?
Don-Wi
08-30-2007 12:28:06
I just kept a running tab in my head how much time I've got just in mounting the fuel tank fenders and wireing up the lights, and I think I've got atleast 20 hours so far.
I had to make new harnesses for the fenders from scratch, plus I added another set of lights and another fuse, switch, and harness from the dash. I wrapped all the wires together with electrical tape (5 2-wire harnesses total), used heat shrink tubing over the ends of all the terminals, and where I ended with the tape so it wouldn't start to unravle in a couple months. I think I started on it last week Tues. or Wed., I can't remember which, but I've spent about 1 1/2-2 hours every day before going to work, as much time as possible on the weekends, and even some time after coming home from work at 1:30 in the morning.
Good news is, the lights all work just the way I want them to. I haven't even started working on the fuel lines yet- they'll have to wait for now. I still have a few other things I need to do yet, but the lihgts are DONE. I'll have to take a picture at nights.
Donovan from Wisconsin
Mike (WA)
08-31-2007 08:39:18
 Re: ever keep track of your hours? in reply to Don-Wi, 08-30-2007 12:28:06
Most of us don't want to be reminded of how old and slow we are getting, and how much time it takes to spend all that money on parts.
Super 55
08-30-2007 18:44:08
I keep track of my years!
Vito
08-30-2007 17:13:47
Gentlemen,I never keep track of my hobby hours.If I did I could never regroup the money.Got months into my 77 project if you count scouting for parts.
Vito
old
08-30-2007 16:50:41
I do it some times just to use it later so I can tell people how long it takes to do this or that. Like I did that once when I needed to pull an engine out of an 8N ford. Took me less then 2 hours to do it, unless you count the braes I took in between becuase of my bad back
Grub
08-30-2007 15:33:20
It can be a bit discouraging to keep track because I always underestimate by half how long it takes. My 10 hr tasks take 20, etc. I stripped all the rotten wood off my trailer, then I cleaned it and then painted it and then welded up a new frame for the sides and then straightened the bottom and then corrected the axle shift and then bought PT wood for the deck and sides. It was just gonna be a simple job...bet I'm in to it 30 hrs.
One shining moment is the lights worked before I started and they still work now.
Taking so long is aggravating but it sure is nice to look at something and know it is done right and will last.
Keep it up Don!
