88 Diesel - fuel in oil
Joeb
08-29-2007 19:57:21
My oil level is increasing a little. It"s not coolant, so Im going put a Korves kit in the lift pump, change the oil, and watch it very carefully. If that does not fix the problem, which seals or gaskets in the Bosch injection pump are suspect? Are gaskets/seals for the Bosch hard to obtain and hard to replace ?
Thanks
Larry from md
08-30-2007 05:00:29
 Re: 88 Diesel - fuel in oil in reply to Joeb, 08-29-2007 19:57:21
There is one oring that seals between the oil and fuel and is easy to replace. If it has not been replaced in a long time you should change it anyway. Its difficult to explain where it is maybe someone can poast a picture.
oliverdave
08-30-2007 04:28:41
My 550 did the same thing and it was the lift pump(or fuel pump).
