2150 hydraulic check...
MattPage
08-27-2007 09:22:31
Well I put a pressure guage on the demand valve plug hole by my left heel, started the tractor, zero pressure, zero steering, zero lift on the remote or three point. yep it had oil. Guess I'm looking at at least a pump? Thanks, Matt.
J Schwiebert
08-27-2007 13:07:24
 Re: 2150 hydraulic check... in reply to MattPage, 08-27-2007 09:22:31
Does the PTO work? I would also check the relief first and crank it over and see if oil squirts out if you have the relief out(put a can over the hole-get someone to help you.
Daniel Ky
08-27-2007 10:49:56
Have you checked the pressure at the relief valve? The relief valve plunger on my 2150 was worn and would not build pressure.
