Strong arm 55
Joe
01-14-2000 21:49:54
I have a Oliver 55 that has to hold the record
for the hardest to turn. I have shered the pin in the stearing box 2 times now and am wondering is it only my 55 or are all of them like this.
Mongo
01-15-2000 10:23:37
 Re: strong arm 55 in reply to Joe, 01-14-2000 21:49:54
I would guess that your steering wheel probably has most if not all the rubber off of it. I say this because the rubber flange to the steering wheel acts like a water shed to keep water out of the steering box. If water gets into the box, the bottom bearing is probably shot. There are two of these bearings, one above and one below the block. Inside the block there are 60 (sixty) ball bearings. With this much surface area, just a little rust does alot of harm. Also, the thrust bearings on the front spindles tend to go bad. These and the bushings need to be checked. The brass bushings run about $45 a side but the thrust bearings are only $6 a side. If you don't get the wobble out with the new bushings, then the new bearings won't last long. If it sounds like I am familiar with the steering problem... it's because I am. Hope this helps.
mmiller
01-15-2000 10:17:11
I believe oliver produced two different ratios for the Super 55's steering box.I think the initial ratio was about 11;1 and the second around 17:1 I would suspect you have the earlier ratio.
Bob S
01-15-2000 09:26:21
Sorry to tell you, but it is just yours! Mine turns like a dream. I know of some with big front loaders who complain they are hard to turn, but the little Super55 is not designed for a heavy load over the front end.
Do you have old style 1 or 3 rib tires on the front? I've seen some with turf tires, or worse yet truck tires, on the front end...those are harder to turn than the old style 3 rib designs.
