Max rpm's out of super 88
scdietsche
08-25-2007 10:04:03
I got this 1954 Oliver Super 88 and was wondering the best way to get the most rpm"s out of her. thanks, scott
BlakeG
08-26-2007 18:12:48
 Re: Max rpm's out of super 88 in reply to scdietsche, 08-25-2007 10:04:03
Im running my gas super 88 3000 rpm, i wont go any more then that with a cast flywheel...atleast thats what i been told not to exceed, and that was from more then one source....but if built ro high rpms ive seen some running 6000 rpms....thats with a steel flywheel and a fliud crank balancer on front
J Schwiebert
08-25-2007 11:46:28
Gas or diesel? How early of a Super 88? Remember the first almost 1000 had cast iron pistons, does yours? How good of a set of pin bushings are in it. Are you going to balance the engine? Just asking: J.
scdietsche
08-25-2007 12:58:30
 Re: Max rpm's out of super 88 in reply to J Schwiebert, 08-25-2007 11:46:28
its a gas, 1954 was the first year the Super 88 was made and we just had the engine overhauled
J Schwiebert
08-25-2007 15:22:50
 Re: Max rpm's out of super 88 in reply to scdietsche, 08-25-2007 12:58:30
O. K. So new sleves & pistons, rods reconditioned engine balanced? What RPM range are you thinking? Also what are the last three digits of your serial number. In other words do you have the slow speed ring & pinon? FYI for you, the first super 88 I overhauled back in 1961 was a 54 model with the cast iron pistons. That is why I asked. We also had two we put short blocks in that spring because a rod went through the side because of improper pin bushing fit. Your turn. J.
