narrow vs wide front end
Craig A Tull
08-24-2007 18:49:11
Other than turning radius what is the advantage of the narrow front end over a wide???
pa dave
08-26-2007 17:33:18
 Re: narrow vs wide front end in reply to Craig A Tull, 08-24-2007 18:49:11
in the 60s wide fronts realy caught on when everyone was going to haybines. with wide front you wern't driving over your windrow, there for faster drying time, better hay.
MCL
08-25-2007 10:00:42
If you are going to mount a loader or work on slopes you want a wide front. They are a lot more stable.
rrlund
08-25-2007 06:53:03
I think the whole basic reason for a narrow front in the first place was to make it easier to put on and take off a cultivator. Remember,back when they were being manufactured,we didn't have the means of chemical weed control that we have now.
old
08-24-2007 21:54:12
As bradk say plus if you have a wheel bearing go bad or a flat tire you can take off the problem tire and keep going where as with a wide front you can't. Also the trike type is lighter then the wide front
bradk
08-24-2007 20:30:26
Cheaper to order with the narrow when new and takes up less space in shed.Also less parts to wear out.
