Update on the fuel tank fenders
Don-Wi
08-24-2007 18:27:58
It was raining today in my great outdoor workshop, so instead of finishing the mounting of the fenders I went to Tesch Bros. in Seymour and got some parts and asked Ron about how they hook up. He copied a couple pages out of the service buletins for me and then took me across the road where they keep a 2050 w/ fender tanks on it and he showed me how they're set up on his.
The way it's supposed ot be done: The 2 tanks come to a T on the right side at the back of the platform, then the one line is routed to the fuel return at the top of the other tank. When the tractor is running, it draws a little siphon on the main tank and then it pulls the fuel out of the other 2. One thing I hope is that the gasket on the fuel sender is good, and the non-vented cap is good too. If not I may be in trouble if I have to let it sit for a while and the tanks are full, or if they're bad and don't draw a siphon...
BTW- the filter for the filter conversion on my 1855 is for an Allis Chalmers 7-8000 series tractor. A little disapointed he couldn't use the right size threads on the adapter for an Oliver spin-on, but there had to be room for the bolt to get in there. I might almost have to make one now that does use the right threads...
Otherwise the poor guy who owns the 1855 some time in the future(not saying it'll ever actually happen) will have a heck of a 1st oil change experience...
Donovan from Wisconsin
Cummins 1955
08-26-2007 15:44:40
 Re: Update on the fuel tank fenders in reply to Don-Wi, 08-24-2007 18:27:58
Then I put a White cab on my 1955, I used the saddle bag tank that was used with the White. It bolted right on and instead using the engine pump to lift fuel I mounted an inexpensive 12 volt fuel pump. It only holds 16 gallons, but is usually enough to get through a long day. When my main tank shows its low, I turn on the electric pump and fill the main tank back up. I do not use it often, but is much easier the carrying fuel to it, or worrying about the right cap.
J Schwiebert
08-25-2007 09:37:06
Don: I don't know what the man copied for you but I did find the other day that I do have an operators manual for fender fuel tanks. If you want a cpoy let me know. Trust me, the right cap at the right tank is the key and yes they will collapse the tank!.
Don-Wi
08-25-2007 19:29:59
 Re: Update on the fuel tank fenders in reply to J Schwiebert, 08-25-2007 09:37:06
He couldn't find the one for the actual fender tanks, but he did find the pages for the installation of aux. tanks on the cab sides. Same basic principal and it was enough to give me a picture of how it works.
If you can email them, my address is- [email protected] I'd still be interested in a copy for those tanks.
super99
08-25-2007 00:51:45
You will like the fender tanks when you get them on and are using them. You mentioned shut off valves and being able to turn off tanks when not using them. IF you do this, be sure to switch the non vent cap with a vented cap before you run it very long. There is enough suction that after using most of a tank of fuel, it will collasp the main tank. Don't ask how I know, just believe me when I'm telling you the truth. Learned the hard way 25 years ago, Chris
Don-Wi
08-25-2007 01:11:17
 Re: Update on the fuel tank fenders in reply to super99, 08-25-2007 00:51:45
We don't put too many hours on the 1855 in a year, but it would be nice to leave it up the road and not have to worry about running out of fuel. There has only been 1 or 2 days that I can remember running a full tank of fuel through it in one day. Otherwise, it's really pretty easy on fuel.
Did the tractor you collapsed the tank on have a lift pump or no? Our 1855 is a later model w/out lift pump so I think it may just starve out. Either way I definately won't forget to switch caps if I use only the main tank.
Probably the biggest hassle I'll have is the extra wireing I'm going to do to add another set of lights. I'll put another switch and fuse in the dash and then I'll be running 2 work lights and 2 headlights on it, as well as the other 5 on the original switch. Should light up the field like a church on Sunday... Mainly use the headlights when chopping corn and maybe some plowing... Can never have too much light out there...
If it were a gasser, I think I'd be afraid to fill all 3 at once...
Here's a picture of last year running the old Fox 3000- third party image
super99
08-26-2007 04:37:32
 Re: Update on the fuel tank fenders in reply to Don-Wi, 08-25-2007 01:11:17
Don. It was a 1950T. It came with fender tanks and I bought a Year Round cab for it and cab wouldn"t work with fender tanks, so I took them off and forgot to switch fuel caps and went out plowing. Had to get a new fuel tank and then got a front mounted tank and hooked that up. Chris
