How do you pull a pto shaft out of a 1850 Oliver
Geard
08-22-2007 18:43:30
I need to know how to pull a pto shaft that runs off the engine out of a 1850 Oliver. I pulled the plug and there seems to be a bolt behind the plug. Do I remove the bolt and what do I use for a puller. I pulled the plug out with a bolt.
Wisconsin Cowman
08-22-2007 19:56:46
 Re: How do you pull a pto shaft out of a 1850 Oliver in reply to Geard, 08-22-2007 18:43:30
What I use is sliding hammer with bolt welded to a nut that screws on the end of the sliding hammer and thread the bolt in the shaft. Sometimes they cane be buggers getting them out and other times they come out very easy.
Geard
08-22-2007 20:04:46
 Re: How do you pull a pto shaft out of a 1850 Oliver in reply to Wisconsin Cowman, 08-22-2007 19:56:46
Is the bolt suppose to be on the shaft?
Wisconsin Cowman
08-22-2007 20:14:22
 Re: How do you pull a pto shaft out of a 1850 Oliver in reply to Geard, 08-22-2007 20:04:46
You got to get a 1/2' bolt and there are threads in the shaft and screw the bolt in a couple of turns. Then you can pull it out however way you want to do it.
thhill
08-22-2007 19:32:43
there is a snap ring and an o ring in there. take a couple picks and remove the oring. then take a long 1/2 inch NC bolt and start it in the threads in the end of the shaft pull shaft out. It can hang up on the hyd pump idler gear twist alittle it should slide through. It can be frustrating but it will come out.
Wisconsin Cowman
08-22-2007 19:21:53
I'm little confused with what you are saying here. Are you talking about the pto shaft behind the tractor. Or the long shaft that runs the pto . Either way there is a snap ring in the pto shaft behind the tractor it is counter sunk in there. You have to remove that and you should be able to remove the longer shaft out of there.
Geard
08-22-2007 19:33:44
 Re: How do you pull a pto shaft out of a 1850 Oliver in reply to Wisconsin Cowman, 08-22-2007 19:21:53
Yes it is the shaft that goes to the engine. I took out the snap ring, pulled the plug. Now there is a bolt, do I remove the bolt? What king of puller do I use to remove the shaft?
Fern(Mi)
08-23-2007 05:33:13
 Re: How do you pull a pto shaft out of a 1850 Oliver in reply to Geard, 08-22-2007 19:33:44
Remove the bolt. It was put in there to push the drive shaft further into the flywheel gears for a better more complete meshing of the front most spline. (I know. Had problem with one of these shafts on late model 1850 striping off half the spline.) Find yourself a 10" to 12" x 1/2" bolt to turn into shaft several turns. Now, pull on the bolt (your handle (or jerk) on the shaft) Sometimes the shaft comes right out. Othertimes it can be an off and on three day jerk on the cussed shaft. Bro" has found it benifical to his thinking to rattle the pto control lever for and aft while jerking on the shaft. Myself I like twisting the pto back and forth. Most of the time it"s either easy or greased with cussing.
Enjoy
Fernan
