FMQc, about that Ford to Oliver steering conversion
Super 55
08-22-2007 00:24:37
I was thinking, since my top end of the shaft is fine, I could cut the shaft, and graft on the bottom section of the Ford shaft. Could even graft on a pipe sleeve for more strength if needed. That may be easier than machining the top end.
original message:
"When I rebuilt my steering box, I bought a Ford 600 steering shaft assembly from AI. I had to get the upper part of the shaft machined to a smaller diameter to fit the new upper bearing. It was also longer than what I needed but since the Ford splines were different than my Oliver steering, I got it shortened to the right lenght and machined new splines at the same time. The bottom of the shaft assembly was identical to my original oliver shaft. Good luck "
FMQc
08-22-2007 05:52:35
 Re: FMQc, about that Ford to Oliver steering conversion in reply to Super 55, 08-22-2007 00:24:37
If you put a pipe sleeve over the welds, you will not be able to slide the shaft through the bearing located at the bottom of the steering column.
I dont know how a welded steering shaft would last over the years. In my situation, I couldnt use the top end of the old shaft because the original splines/steering got loose and both were damaged. I only had to bring my new Ford shaft with the new steering to the machinist and he made the proper splines and treads to join both. I can confirm the bottom section of the Ford 600 shaft is identical to the original shaft.
Good luck
Super 55
08-22-2007 09:04:07
 Re: FMQc, about that Ford to Oliver steering conversion in reply to FMQc, 08-22-2007 05:52:35
Duh.. of course. Thanks for waking me up. And thanks for doing all the previous work to discover the solution. How did you discover that the Ford 600 column would work? Also, did you happen to look at an 8n shaft? They look very similar looking at the drawings of the parts.
FMQc
08-22-2007 20:40:01
 Re: FMQc, about that Ford to Oliver steering conversion in reply to Super 55, 08-22-2007 09:04:07
I knew some Ford models had the same style of steering box than the Oliver S55. I also read something about that in the archives of this great forum.
I had to make a guess and order one to try. You're right, 8n shafts looks similar but I wanted to be sure that it was long enough. Maybe 8n style works also... I should have taken notes of all the dimensions where I got the Ford shaft machined.
If you go that route, I recommend you to have all the parts with you before taking it to a machine shop. That way, you can measure everything. For example, to fit the bearing at the top of the column (right underneath the steering) you will have to get the shaft machined down a little and then get new splines made up. Also, I read in the book that some S55 had short steering colomn, later they went for a longer model before going back to a shorter column for the 550. It looks complicated but its not so bad.
Did you ever get my email about the stay rods?
Sorry for the long post.
