Brake problem
cmccoy
08-19-2007 14:03:04
I have a 1963 770 gas that I am very near to sandblasting but I am trying to button up any little thing that needs attention or fixing before sandblasting. My problem is this, on the right brake I cannot tighten up the cover plate on the side without locking up the brake. Then when I loosen the plate the wheel is free again. The other side works fine. Any ideas? It did sent around 10-15yrs prior to the restore. Thanks in advance for anyones thoughts and ideas here. Chris
olrusty70
08-19-2007 16:37:32
 Re: Brake problem in reply to cmccoy, 08-19-2007 14:03:04
Chris,
This can be a very simple fix. First with the cover off when you apply the brake does the center section act like it is applying the brake? If it moves then on the bottom side of the brake peddle (bottom of the brake housing) is a nut that has a ball on top of it this is the adjustment nut for warn brakes. Loosen the nut until there is play in the peddle. Install the cover and adjust the nut to get around 1.5 inches of free travel.
If the center section does not move remove the adjustment nut. Remove the brake center section from the tractor (It will come out) and take it apart to clean it. There should be springs on the inside to captivate the balls between the plates. Free up all the linkage at the bottom (APPLY neverseze) I am sure for setting that long they rusted up. My 880 did and it sat for only 3 months. Put every thing back together and install it in the tractor. Good luck! If you need parts I might have a few parts left over from my 1600. Brian
