hydraulic fluid for 1650
Rich Iowa
08-18-2007 08:18:03
I"m just wondering what others are using for hydraulic fluid in their XX50 series tractors. The manual says to use 10 weight engine oil, but I"ve been topping off the system with universal hyd. fluid from the local farm store. I"m begining to think the stuff I"m using is to thin as I top the system off alittle more than I used to.
Shovelman
08-19-2007 17:23:53
 Re: hydraulic fluid for 1650 in reply to Rich Iowa, 08-18-2007 08:18:03
We have used Castrol UTF in the hydraulic, HydraPower and Over/Unders in both of our 1650s and 1655 for years with no problems.
If you topping-off often, best to check the trans/diff oil level to see if it is over full. A leaking pump seal or cracked hyd sump pan could be the culprit. Good luck.
Wisconsin Cowman
08-18-2007 10:07:30
I use 821 use it in all my tractors and skid loaders.
Don-Wi
08-18-2007 08:35:53
We've got a pair of Massey's, so we run Perma-tran III in everything on our farm. Keeps it much simpler.
Donovan from Wisconsin
